Cro_Tom
Hy, i have a problem with fiat bravo 1.2 16v 2000. with tartarini lpg.
Before 4 weeks car was in service, they changed head seal because seal was bad, and car was spent 1 liter water per 3-4 days.
After that service, I have a next problem with idle:
1.) When car and engine is cold (morning), car won't start normal, i need to manual add a little throttle (gas), and then car start. But then idle fals to 500-600 rpm, and car turn off.
I must add a very little manual throttle to car work normal. If I don't add a manual throttle, car every time turn off, and won't start without throttle.
2.) When car is hot and is on work temperature, idle works normal!
Car start's normal without manual throttle.
Ok, it is not every time good, in 90% car idle is good.
But when is cold, idle is bad every time!
Where is problem?
Is there a problem with idle control valve, or something else?
I was been on 2 diagnostics, but none found the problem.
They clean a idle body, reset the idle valve positions, but nothing hapened.
Same problem is and on gasoline and on lpg.
Sory for bed English!
Where is problem?
