Fiat 500L fuel regulator fault
So we need a new HP pump? Or injectors?
Who suggested that?
You told us it starts on a spray.. then runs ok..
So pump is working ok at higher revs
Unused fuel is designed to return to the fuel tank..
You might have more than normal teturning.. so the pressure tails off quickly :eek:
Did you get a rail pressure once ticking over ?
Who suggested that?
The pump works at higher revs but not lower revs.
Only low rail pressure once ticking over
