What fault code are you reading from ecu?Hi, could anyone help with the fault fuel regulator? Is this easy to change and where is it located on the vehicle
post the fault code that is letter p followed by four numbers
How long was it run on petrol?Petrol, after emptying and putting new in it started ok and run for a few weeks. Now it will start with easy start and cut out. It wont drive fa
The fuel pump has been replaced so im assuming it works properly
Yes showing 110Did you say you had a tool to measure rail pressure?
What figure was it showing
Needs to be HUNDREDS of Bar..
Or it wont allow injection
These motors have been around for 15 years..
Most issues have been seen on here before
Do not put any part of your body anywhere near any of the high pressure diesel pipes or fittings when they are open or loose.
The pressure of the fuel is more than enough to push diesel fuel through your skin into your flesh- this can kill you or require the affected limb/area cut off.
Yes showing 110
