Technical Fiat 500l 63 plate Dpf pressures sensor locat
chrisw1973
Northampton
Hi, where is the dpf pressure sensor located. Had a dpf clean recently and they forgot to tell me I needed the pressure sensor replaced. So the light has come in again. I was hoping it was an easy replacement.
Assuming it is not a case of their cleaning job didn't work and they just told you the pressure sensor was faulty, can you not follow the two metal pipes , one before and one after the DPF filter back up to the pressure sensors, often on a bulkhead somewhere near the engine?
Did you get any readings from MES or some other diagnostic tool to guide you?
Is this the 1248cc..or a bigger mj?
Panda 2012 section has best 'hands on' ownership ratio here :)
