- Joined
- Apr 26, 2011
- Messages
- 2,102
- Points
- 358
You know, bgunn, it's bad when the mods start siding with the trolls...
I got sick of messing with points and such like at the side of motorways.
But you said that the older cars were better because they didn't have 'redundant kit'? Sorry, but surely you can see you're being a hypocrite here?
Oh, and I side with myself. Daniel and I have had plenty of arguments in the past.
The whole point I'm trying to put across is, S&S is a wholly redundant bit of kit for any driver with common sense. If you're stopped in traffic, you stop the engine. Similarly, common sense tells you that, if you keep doing that, you'll screw up the battery.
I take umbrage with what you're saying about lacking common sense and think you're somehow of 'higher order', on behalf of myself and many others who have no problem with S&S doing what it's designed to do.
It's funny, but common sense would tell you to do some research in that the battery on a micro-hybrid car is not the same as a standard car. So it is designed for the higher demands placed upon it, it has a greater charge acceptance rate, and can stand greater discharge demands without failing like a standard lead/acid cell.
Equally, the starter has a higher duty cycle, with a different drive gear - i.e. it's 'better engineered' for those of you with more common sense.
Also, the engine management software has been improved to learn the crankshaft and sensor tooth pattern to such precision that it actually can see the different 'shape' of each tooth (in terms of how it's machined and the difference in magnetic flux generation in the relevant sensor) ensuring that the exact position of the engine can be determined within only two to three teeth passing the sensor tip. So the engine management can fire the coils and injectors with less rotation of the engine at start up, meaning less fuel is wasted and the engine starts more quickly. Sounds rather like 'common sense' to me.
Oh, and should the electrical demands still be too great, common sense dictates the S&S turns itself off!
Those of us *with common sense* keep S&S turned off...and put up with the annoying little amber light.
BJM
I now actually find the thought of my engine idling whilst I'm in traffic quite an alien and rather backward concept. I mean, you would leave a kettle boiling all day on the off-chance you want a hot cup of water three times a day, would you? The S&S is hardly intrusive, is it? The engine stops when you disengage gear and de-clutch - which you should be doing when you're going to stop for more than a few seconds, right? So it's common sense, isn't it?
I don't wish to be rude or cast aspersions, but I just don't see what the issue is. But each to their own.
