Technical  Fiat 500 gear box issue help needed
Gale Force
London
Technical No Gears available​
Unwatch
Gale Force
New member​
Hi everyone I’m new here and have a problem with my 2008 Fiat 500 Duologic was driving home on M25 when the red gearbox warning light came and a message to check owner manual, I drove for another 35miles with no issues apart from warning light, I stopped switching off ignition to see if would clear fault message and light, I restarted but lights still on and no gears now, just message saying no gears available, got AA to tow me home. Removed heat shield covering fluid resovior and found to be empty!!! Filled to level with Cs Speed and opened drivers door to start pump and fluid disappeared repeated 3 times and fluid disappeared again🙆‍♂️ I’ve been all around the gearbox and no signs of leaks, does it take more than 3 to top up ? Please help I’ve spent hours searching for answers???
Regards Gale Force
Unwatch
Gale Force
New member​
Regards Gale Force
Definitely shouldn't take that much
Your unit is probably leaking into the pressure vessel or elsewhere in the gearbox
But I aren't too familiar with the technical side of these
They have a 2nd thread running about this,
I have linked to technical info 🙂
