lczoccante
- Joined
- May 30, 2021
- Messages
- 2
- Points
- 1
Hi everyone,
While driving my Fiat 500 0.9 TwinAir semi-automatic on a busy road, I suddenly received a warning on the dashboard that read "Check transmission see handbook." As a result, I lost engine power and was unable to engage any gear. I ended up having to stop in the middle of the road. Despite trying to turn the car off and on again, the error message continued to display (similar to what happened in this video attached below).
After a few more attempts, the car finally started working again, but the experience was quite scary. Has anyone else experienced a similar issue? After doing some research in this forum, it seems that a low level of transmission fluid could be the cause of the problem, but not sure. it was a damp road, I was wondering if could be some electronic issue ?
Anyone has any suggestion ?
I am from north London UK if anyone know a good FIAT specialist in London that can look into this dualogic system ?
Thank you.
Thank you.
