Technical Fiat 500 axle rust on axle pans
MikeJohn
Leicester
Hi there,
My daughter’s fiat 500 failed its mot today. The axle pans that the suspension struts sit on at the rear both have small holes in. The garage said as they are so small they could be welded. I can see this is a common problem on fiat 500s of this age. Could anyone offer any advice on whether this would be suitable or do I need to replace the whole of the rear axle? I have attached a few pictures .
Thanks for any advice in advance
Mike
Model
Fiat 500
2013
Mileage
100000
How long do you want the car to last is the real question?
If only a year or so weld up, if you want say another 5 years which is quite possible replace it(axle) a competent DIY person can do it over a weekend with all the right parts and tools, but not if you're unsure.
The car is entering the point where lots of age related things need sorting, this can be very expensive if you cannot do it yourself?
Yes will probably look at welding it and sell it if possible. I can see an aftermarket axel for around £150 but then with labour costs might be another £500 or so and the car probably isn’t worth more than 1k? I can’t do the work myself so will have a look get some one in. Thanks for your response .
Weld it up, mot it, but keep for another year, it's going to be cheaper for now, why sell a car with another years mot to someone else when you can use it?
Events Team
Join the team
Psst! Are you free August the 2nd??
Then come and join us at FIATs and Friends.
Held at the British Motor Museum, there will be loads to see and do so there's no excuse not to be there 😜
Sign up using the link above to register yourself for our stand - everyone is welcome!
hi thanks for the info it failed on
  • Suspension component corroded and seriously weakened Nearside Rear Lower (as marked)
    [5.3.3 (b) 01
  • Suspension component corroded and seriously weakened Offside Rear Lower (as marked)
    [5.3.3 (b) (i)]
The advisories were -
  • Coil spring corroded Rear (both) [5.3.1 (b) (i)]
  • Sub-frame corroded but not seriously weakened
Do you think the mot centre will pass it if they can see it’s been welded.
This has been covered before,
You could get a flat disc cut and laid in there,
welding is only tacks / stitches in that instance
Thanks , do you think the mot centre will
Pass it if it’s been welded . The pan looks badly corroded and wonder if that can weld onto this ok?
Like a sill, or other structural item
You just need to restore the structural integrity,
Surface rust, etc isn't an issue
Plated and repainted it should be fine
Maybe look for a Local mobile mechanic..
They Could fit replacement rear springs too as it's the same job..
Might look better when selling in 11 months
