Completely unrelated.. I have 2 twinairs.. They are generally pretty toughMine is a Twinair which I understand has a cam chain - running (very) well so...
I wasn't sure how big a drive that was..?Try coming over the bridge to willerby hull and see Alan at woodcock motors he solved the same issue for me for £65. He’s very genuine and honest.
Yes Thankyou, we will take a trip over the river@Terrijane10
Could this work for you?
Thankyou for the heads up I will give him a call.I would give Alan a ring first 01482568956 as he’s a one man garage.
Hi I don’t suppose you’ve found any solution for your daughters car? I’m a Nissan technician myself and my girlfriends mam has a 14 plate fiat 500 which is doing the exact same! It’s causing her anxiety driving personally never had anything like this before. However hers is throwing an engine light on just like yours , I plugged in the code reader and it’s related to the intake manifold as an air leakage. I removed the map sensor which was oily & cleaned it off car ran much better. Also due to short journeys the engine is full of gunk in the breather pipes ect.. it’s definitely an air related issue Im going to put a new map sensor on, give the engine a clean, use the gunk remover you can buy in petrol stations and give it a fresh service followed by a long motorway run. Your issue sounds very similar so double check there’s no gunk on the breather pipe which is on the airbox , throttle body covered in gunk ect . Hope this helps or you’ve already got it sortedSorry hijacking this post too, My daughter's 14 plate fiat 500 doing exactly the sameour local garage had it for 2weeks and couldn't find a fault yet once again driving to Essex from Cleethorpes gets to the A1 and limp mode sets in once she overtakes and hits 70 start stop/light and engine management lights are on, she pulls over and stops the car then starts it up and all lights have disappeared. This happens 3 plus times on her journey, yet on her way back to Cleethorpes if she stays around 60 it doesn't happen but she can't keep driving down them main roads at 60mph it's dangerous
Any advice for a worried mum![]()
We thought it had stopped but she's since told me that it happened again on the m25 twice the other nightHi I don’t suppose you’ve found any solution for your daughters car? I’m a Nissan technician myself and my girlfriends mam has a 14 plate fiat 500 which is doing the exact same! It’s causing her anxiety driving personally never had anything like this before. However hers is throwing an engine light on just like yours , I plugged in the code reader and it’s related to the intake manifold as an air leakage. I removed the map sensor which was oily & cleaned it off car ran much better. Also due to short journeys the engine is full of gunk in the breather pipes ect.. it’s definitely an air related issue Im going to put a new map sensor on, give the engine a clean, use the gunk remover you can buy in petrol stations and give it a fresh service followed by a long motorway run. Your issue sounds very similar so double check there’s no gunk on the breather pipe which is on the airbox , throttle body covered in gunk ect . Hope this helps or you’ve already got it sorted
From research believe you’re right, personally thought it was a map sensor but seems to be the evap solenoid causing map sensor to be full of oil. Going to replace this on Saturday soIf it's a 1.2 petrol ....the evap canister solenoid valve can be an issue. It is fitted to the inlet manifold with a blue plastic pipe connected.
Hi, any chance you have contact for Alan? Have the same issue… several mechanics tried to help and charged me a lot… I keep spending money and problem still the same. Just need Mr Alan to help me and I am willing to come and see him from Hertfordshire. The problem is that it seems like Woodstock Motors in Hull no longer exist…Try coming over the bridge to willerby hull and see Alan at woodcock motors he solved the same issue for me for £65. He’s very genuine and honest.
It's Woodcock..Hi, any chance you have contact for Alan? Have the same issue… several mechanics tried to help and charged me a lot… I keep spending money and problem still the same. Just need Mr Alan to help me and I am willing to come and see him from Hertfordshire. The problem is that it seems like Woodstock Motors in Hull no longer exist…
lol yes… got the name wrong. Found them now and called however they are closed until 23rd of September
