Styling  F4usT - Silver B
New in the UK from Fiat or DTR £1100.
Second hand £500 - £700 depending on condition.
The side covers for inside the car are £55 each!!!! So + £110 if they are missing.
not sure... those existing holes are so hard reachable, probably will drill another ones. this should be very stable and well bolted. and rollbars will be bolted with "U" metal things (second picture). First picture shows bottom of speaker box, red line is metal plate that will press down whole thing.
You know the petrol tank covering (The huge metal plate)
Could you also bring the front of this up through that metal plate? The top of that metal plate, remove the bolts and buy longer ones, then place the bottom of your thing on the top of the metal plate inbetween the body and plating.
This is what I am doing. I also bought some Merc Roll bars as they are not round and look slightly different.
Will post pics when she is done. (y)
yes that metal plate will be used to bolt rollbars, and those "U" metal things will hold speaker box close to rollbars to avoid moving.
here's example what i had in mind; a sandwich plate. that red thing is petrol tank covering plate. it have some holes, but they are hard to reach from the bottom.
right picture shows holes on that metal plate. on top there are small bolt holes and from bottom are huge holes but are moved and are not exactly below bolt holes (only middle one is exactly bellow). you cant put your hand inside.
one way it to create another hole all through and fit it as on first picture.
hi. need help about size of rollbars. on first picture, do you think i should lower them? make them smaller... they looks to high even that one i cut. i think they should be aligned with seats... or little higher than seats.
yup i agree with you,, they look better when they are aligned with the seat and the curb is a bit larger. good work though so far!!!
I hear there's about to be a PM looking for a new job in the UK too! Perhaps he could be sold to Croatia, just as long as they have a flexible attitude to expense claims.....
how is going on, our next PM will be Alan B'Stard
just ordered EL foil from some guy in Hong Kong. will try to create "plasma dals" for heater control.
idea is to cut round EL foil, cut not-see-through foil with holes for signs, and between EL and that foil put some transparent foil in color...
here is some quick video:
greetings from Zadar!!! finally vacation... hitchcock says that zadar have the most beautifull sunset in world. pictures will follow... also there is one red barchetta in perfect condition.
Pozdrav F4usT :)
ti si nevidjen fanatik prijatelju :)
pozdrav iz Srbije.
Hallo F4usT :)
u are fanatic my friend :)
greetings from Serbia.
:eek:
pozdrav i tebi susedu (y)
here we go again...
this cost me 40€ with some MaFra polish stuff at fiat dealers. not so cheap but here are results... now i can see in dark. before was like looking thorough a bottle of milk...
before (don't have pictures right before polishing, those were taken 2 years ago... imagine how they look after 2 years )
after
speaker box... some weird.... still a lot of work.
