Technical Exhaust flange clips
Martinjbyrne1
Hi, my exhaust started blowing recently and at first I thought it was the flexi pipe, I've just found that it isn't. Instead it has come loose at the cat to centre pipe flange (clips must have come off) I cant find the clips anywhere can anyone help?? See picture attached. Cheers
Just put some nut & bolts on if any of them as snapped just drill them out first
I've just replaced the complete exhaust on our GP, the fixings for the pipe to cat were just two nuts and bolts. Some exhausts I've changed these have been studs welded to the cat side and then nuts on the exhaust side. As BFG says, if they're studs you'll need to drill them out (I've used a dremel mini grinder in the past).
