Ethernet Hub questions...
leeds
Hi guys, sorry to trouble you, tried finding answers from other people but figured this site is the 'hub' of usefull info,
Ok allow me to begin with, I have my BT hub upstairs connected to computer, its got wireless which works in every other room in the house except the one where i play on my xbox,
so i have ran a cable down to the room which is plugged into my xbox, but when im in there and want to use my laptop at the same time i cant always get a decent wireless connection which is a pain.
In short would a Ethernet hub, split the connection between my xbox and laptop or is it something else id need to use? Any advice would be welcome
something like this? http://www.ebay.co.uk/itm/5-Port-RJ...puting_NetworkSwitches_RL&hash=item33624c0bc3
Dave
Thanks for this reply, il give it a shot, its just really so i can use my laptop at the same time as xboxing:eek:
No problem mate.
Would this be adequate? http://www.ebay.co.uk/itm/Netgear-FS105-5-Port-Fast-Ethernet-Network-Switch-ProSafe-LAN-10-100-/310340546682?pt=UK_Computing_NetworkSwitches_RL&hash=item4841bcf07a(im just baffled at the minute with it all) :confused:
Hmm seen its a refurbed one and it says 'no fan' would this not overheat or would it not really matter?
No fan in these are fine, I've just bought two FS108 - same thing bit with 8 ports instead of 5 so I can tell you they're perfect and are silent.
http://www.scan.co.uk/search.aspx?q=fs105
^^ Bit more expensive but from a reliable source.
Dom
as said a switch is your best bet or if you wanner go wireless you can get a repeater and repeat the wireless signal nearer the room with your Xbox in
going this route your wanner get a regenerative repeater for the best possible wireless signal
not cheap though :(
arc! hey there, hows it going? thanks for your post, nice looking link from both you and dom, always count on this site to help out no matter what,
Thanks dom for the info on the fan part, was a bit worried that it could overheat but that's cleared that up, will order one this week and post results, :eek:
No problem matey.(y)
Dom
Hey just to report back that i ended up choosing the product you looked at arc, on overclockers, delivered at the weekend and sorted, happy days, works a treat, (y) thanks again guys
