Technical EPS electric power steering faults
I can not pin point it exactly but it does not happen on highway once. Most of the time early in the morning turning on to the street or so.
More frequently from a cold start
More frequently, sharp turn at idle or low revs
Possibly with indicators and heaters on
Sounds more power related at the moment
I removed old the negative and possitive nuts and bolts and with cleaned it with emory cloth inside out, including the inner area of battery terminals. I sprayed contact cleaner and wiped it off with clean towel.
That's a really good start
If you have a battery charger, leave it on charge over night
And see if the following day if it's less frequent
I checked the Fuse and bolt, I also removed the A pillar cover and i could not find a terminal that is shown in the Diagram but i found another ground with DELPHI written on it.
All the bolts and connections looked corrosion free i nevertheless removed them and the bolts, cleaned everything with emery cloth and sprayed contact cleaner, wiped it and retighten the bolts. I will try again tomorrow but i do not think they are the reason. Everyconnection that i check on the car until now is either looks like new or only slightly dirty. I could not see any rust or something. I do not have car battery charger but as i said resting voltage is 12.6v. i think it is fully charged.
What i do not understand it car is taking its electricity from the alternator. When the v belt ripped and exploded last time i also lost the Steeringwheel support even the battery is connected. So Alternator is a must for steering right? or am i missing something?
Yep they have changed it slightly, using stud and nuts
Yep look in really good condition everywhere, I don't see anything obvious
It a handy way to check, leave it on charge, put the battery in and see if things improve, it's not foolproof but if the problem goes away temporarily, you know your are definitely chasing a power issue
The battery is like a reserve store, buffer
The body computer controls alternator output to just enough power no more, to save fuel
If the load suddenly changes, the alternator can not keep up, and some will be drawn from the battery. Such as the high load of the steering motor with low revs at a junction
If the voltage sags too much momentary, it shuts the steering off
Strange the steering didn't carry on working when the belt broke, driven a couple of cars with faulty alternators not charging, usually get quite a way until the power steering fails, but never tried it with the Panda
Today i had another failure. It was afternoon, car was warmed up and it happened during turning into the Autobahn.
Last few failures happened during turning to right i guess. I do not have car battery charger but i will ask a friend for it and try chargering the battery. I am growing desperate. It really sucks the fun of driving this wonderful car. I had few problems as i bought the car and slowly but surely i managed to solve them but this Steering wheel is making it harder and the worst part is i do not know what is causing it. Even with stellar tips and helps of members like Koalar and other i am still really confused what might be wrong.
The problem with the Electric power steering is there's dozens of different causes with the same or similar symptoms
Would trying to scan with MultiECUScan tool bring something to light or is it pointless?
I will receive a car battery charger tomorrow and will try to charge battery that overnight.
What should be next step after that? is there anything i can do/control in the meantime?
Not total pointless
It can positive confirm a power issue
But if it says it's the power steering, it could be the power steering, but could be the power going to the sensors also
To use an elm327 you will need the green adapter cable 1
I charged both the new battery and my old one. They were both 12.6 V to begin with and inside of 1 hour mark both of them are fully charged according to the charger. I will try it tomorrow again, i do not know if the situation got better but i am highly suspicious. I have not got any adapter cables, only ELM327 Wifi ODB adapter and laptop will i will install ECUScan tool and try to make generic scans if possible. Maybe it reveals something more than Torque App on my phone.
The steering is on a different none stars pin on the OBD port
If you are handy with a soldering iron you can modify your interface so you don't have to use an adapter
By soldering 1-7-9 together you give you access to the
ABS
Power steering
Modules
Along with the standard engine ECU
But then it's only safe to use on fiat cars
Over here, in The Netherlands, the faulty electrical power steering is a common issue. There IS a fix, however... but it does require getting deep in there.
You'll nee to remove the dash-covers around your steering wheel to access the electrical pcb of your power-steering unit.
The red light is mainly caused by a faulty soldering of the power-leads to the steering unit. Hence you'll need to desolder this board carefully. Resolder the power-leads to the board and then solder it back onto the steering unit.
It does require some squirming into the bottom well underneath the steering wheel, and you really need to know how to solder properly, but many fix it this way and drive thousands of miles with this fix applied, without another fault-warning.
Hope this helps y'all out!
Are you talking about these joints
Don't know yet. Have to figure it out myself still. But from what I see, I would say yes. Those are the ones I'm talking about.
That was a very common fault on the similar Delphi EPS as used in the likes of the Puntos 188
Here in the UK so far I have never seen or heard of one fail here on the redesign part as fitted to the Panda 169
The few cases which haven been a power issue have all been fixed by a new torque sensor
If you could post some picture of the failed part,would be helpful to others
I'm planning on diving underneath the dash this summer, when the weather is nice enough. I'll photo-record every step of the process. (The Torque-sensor might be the issue, as most garages say. However, many fellow panda-enthousiasts discovered it's the bad soldering on the power-leads instead) So, cross your fingers... This summer I'll find my answer! ;) (A new Torque sensor is even on 2nd-hand bargain easily around € 120,- :oops:)
Today I got another red steering wheel on the dashboard along with loss of power steering after 3 minutes of driving. It was not cold at all this morning.
After turning the car off and on it went away and never came back.
The car was not even turning hard, just a very slight bend and the warning came suddenly.
Is there any other area I can check besides the ones I have already checked, (main earth cable, new battery, charging battery overnight, contacts all cleaned and checked, fuse blades cleaned, 12v positive lead going to fuse box cleaned, earth cable under carpet under globebox compartment cleaned).
After visual checks of the cables the next move normally is to preform voltage drop tests between the the main power and return
Underneath the ignition switch there a connector that's worth reseating
If possible, could you describe exactly how I can perform this test? What do i need and what should i do?
I will try to look at the connector today after work, but if possible I would really appreciate a photo of it. I have seen a lot of connectors behind the steering wheel.
Voltage drop testing is pretty
Multimeter on volts , set to around 20V if it's not auto
Probe on either end of what you want to check, then load the circuit
For example the earth for the alternator
One end is the engine block, probe on here
Other end is the battery negative terminal
To load the circuit, pull a main relay out and crank the engine
Should be under 200mV
Let's assume it's not
The problem could be
Cable
Eyelet to gearbox
Terminal post to cable
Put the probes on the cable terminal and the battery terminal and crank the engine
Should be 0mV near enough
Repeat untill you find the voltage drop
To load the steering circuit, turn the steering with the engine on and the red warning light off
Cable
Eyelet to gearbox
Thanks for the detailed instructions, I will try it this Sunday. I have a few questions.
When you say "load the circuit" do you mean just cranking the engine without the "main relay" or turning the wheel at a standstill with the engine running?
Which one is the main relay? i tried to search it online but could not find it. Sorry it might seem a little awkward question but I really did not understand. Do you mean the fuel pump fuse so that the engine just cranks without fuel? (you would have written fuel pump fuse directly if that was the case i suppose but as i said i did not understand. Sorry)
Should the test always be done between the battery negative terminal and other ground?
Battery negative - engine block
Battery negative - alternator negative
Battery negative - gearbox earth terminal
Battery negative - battery negative terminal
I did not understand the last part of your message, how can the engine work with the main relay disconnected?
