Technical  Engine stalling
Mypanda12
Kent
Hi all, hope someone can help, I have just registered on this forum to help diagnose what is wrong with my Mums fiat Panda 2009. The issue is that it appears to intermittently stall, but strangely it seems only when the temp needle is below half way, so it runs fine when engine is warm. Starting from cold is no problem but after 4-5 mins of driving is often stalls. The battery is good.
My mum took it to garage and they checked it out, said it was a cambelt issue, so they replaced that (It likely did need replacing anyway as its done over 90K miles), and said its running fine and gave it back, but the issue persists. Then my Brother took it to another garage and asked them to clean out the throttle body, as someone told him that would fix the issue, but the issue still persists. Yesterday I replaced all the spark plugs, and all the HT leads, checked the two coil packs with a multimeter (both reading within spec), but again the issue still persists. The EML is not flashing up, and a quick scan with my cheapish reader reveals no pending codes, although there is x1 stored code (PO115,Engine Coolant Temperature (ECT) Sensor Circuit Malfunction).
Anyone have any ideas ? So far we have
Replaced cambelt (garage used a cambelt kit)
Cleaned soot from inlet manifold
Replaced Spark plugs
Replaced HT spark plug leads
Checked both the coil packs primary & secondary resistances (both readings are within spec)
Thanks for any help, the garages can find nothing wrong !!
Model
Panda
2009
Mileage
90000
@Mypanda12, your problem is the IACV (idle air control valve) located on the throttle body. That controls the air intake when the gas pedal is not pressed.
Code for the part is MEAT & DORIA 84055.
Hi again. I cleaned the MAP sensor this afternoon, unfortunately It has not solved the issue, its still stalling regularly when engine is cold. I did notice that when restarting from a stall it is not instant like I originally suspected, it takes around 5-10 secs or cranking. I'm convinced its a temperature related as the appears to run fine when warmed up, and similarly if the revs are high when its cold. Would anyone consider it could be an issue with the coolant temperature sensor perhaps ?
No unlikely to be the coolant sensor
Its like the old day of when you had to manually pull out a choke when the engine is cold
The petrol vaporises much easier when it's hot, the car is much more tolerant to the wrong mixture,poor compersion or weak spark when the engine is hot
Your car is running the mixture, much to rich, I can't say why with nothing to go on
If you have an android phone buy a £5 elm327 Bluetooth dongle, it will serve you well for an future cars as well
Pull this pipe off
And see if it runs any better
It will smell a bit in the car turn the heating control to recirculating will help
I've had this. Brief stuttering at idle, I can't remember what caused it, pretty sure it is didn't fit any new parts, Fairly sure @irc had as well. Maybe a blocked are cracked breather
Trouble is more than one thing can cause similar faults
I be surprised if it was the idle control valve, it wouldn't explain the rich running, or why it holds an idle when warm
Highly likely to be the same as this one
It doesn't operate at its best anymore. It's not completely dead, still opens up but can't keep up with engine running. Low air on the mixture is exactly rich running, so it does kind of explain it.
Was it coved in oil or not
A photo would have helped
Agreed - Probably loose/cracked breather pipe or airbox to throttle body seal, causing oiling up of the MAP sensor.
Seem to be coming across a lot of these lately.
Also check the airbox for cracks, especially the little stub for the breather pipe.
If you need replacement parts, beware - some suppliers have wrong part numbers listed for both seal and pipe. There are a few different sizes of seal, and lengths/bends of pipe for different versions of the FIRE engine.
Thanks for the responses here, I will definitely take at good look at the possible suggestions best I can, but will have to be after Christmas. When I cleaned the MAP sensor it was oily, not dripping oil but a mist of it, I cleaned it with carb cleaner. Unfortunately did not take a pic as could not find my phone at the time. Have not had a chance today to check if throttle body is leaking but will do so when Im able. I did notice yesterday that the short hose from the underside of airbox has a split at the far end where it attaches to throttle body, if you can picture it, its split slightly at the end so a looser fit onto the throttle body. If the Idle Control valve is only a few pounds I will replace if an easy replacement. And sure Koala will remove that pipe and see if runs any better. Thanks so much for your time in responding, wishing you all a great Christmas. I will be back (y)
Thanks for the responses here, I will definitely take at good look at the possible suggestions best I can, but will have to be after Christmas. When I cleaned the MAP sensor it was oily, not dripping oil but a mist of it, I cleaned it with carb cleaner. Unfortunately did not take a pic as could not find my phone at the time. Have not had a chance today to check if throttle body is leaking but will do so when Im able. I did notice yesterday that the short hose from the underside of airbox has a split at the far end where it attaches to throttle body, if you can picture it the its split slightly at the end so a looser fit onto the throttle body. If the Idle Control valve is only a few pounds I will replace if an easy replacement. And sure Koala will remove that pipe and see if runs any better. Thanks so much for your time in responding, wishing you all a great Christmas. I will be back (y)
You ansewerd your own question
The split loose fitting pipe will be the cause
You might have to take the throttle body off
There's likely to a few cc of oil under there
Without removing the oil cleaning the map and put is back in will just be back to square one
Sorry I should have explained it better
I'd hang fire in the idle controle valve for now
There not that easy to change and you've not got a P0505 error code and it wouldn't explain why it's fine when got
You can clean it while the throttle body is off
Yes the pipe does reattach just its not so tight, it seems to slip on easily rather than need to push it on. Removing the throttle body and cleaning is certainly a task I could do, will I need any replacement gaskets ?. Will give that a go when I can and keep you updated. Thanks again
I can picture it. That's what they do. But that doesn't affect at all how the engine works because that goes onto TB where air intake is let in by the IACV and the butterfly. It cracked like that just lets crankshaft/engine block gases exit into atmosphere instead of going into engine again, combustion chambers.
Have a Merry Christmas yourself and get to it when you have time to it.
Replacing the IACV is quite easy and it is quite cheap. I'll guide you through if you want to.
...but it does cause the MAP to get covered in oil, which does affect how the engine works.
Pretty sure here's a FIAT tech bulletin somewhere on here which explains the reasons, but I didn't bookmark it (or it could be in my pile of random tech bulletins that I haven't got round to scanning yet).
Its completely possible that it also has a problem with the IACV but its probably best to fix the one that you know you have, before introducing any new variables.
Cracked hose doesn't do that.
Au contraire, mon ami!
You guys put way too much emphasis on the oily intake manifold. That's just the way it is. It doesn't go quite as you fear it does.
If you want things to be good there make sure rocker cover oil channel isn't blocked and oil pump delivers properly.
I post it nearly every week
PDF Attached underneath
But it's like banging my head against a wall, hopefully Google will start picking this as a correct solution
The gasket under the airbox, how its mounted, pipes not blocked, or not leaking have to be correct otherwise It's effects the combined sensor pressure/temperature so obviously it effects fueling, in tur it effect running
Poor MPG, petrol smell from exhaust, especially on startup, difficulty restarting, sooty plugs, brief drop in revs, poor acceleration, stutter on acceleration
Quick and dirty test is to just remove the breather pipe from the valve cover, on the road a few wide open throttle up to the rev limit and immediately shut the throttle clears the intake manifold of oil
Well it worked on my 2011 1.2 69hp with a blown head gasket, until I got round to fixing it properly, sample size of one though
It's not the only cause, but it quick and easy to check
  • idle.pdf
Actually it does (in any language)
"Oily intake manifold" is not great, but oily MAP sensor is definitely going to cause running issues.
EDIT:
Thanks @koalar.
Thats not the specific one I was thinking of, but it mostly says the same things. (I think it may actually have been a Ford Ka tech bulletin that I was thinking of, but same engine...)
Technically, cracked pipe lets the oil fumes go out, not into intake manifold...
That's what I was saying.
No idea on the logic here
On the panda 1.1/1.2 there's no Air Oil Seperator
It's blow by gassed are just being sucked in
Atmosphere pressure is 100 kPa
Pressure in the intake at idle is 35 kPa at idle
That's a 65 kPa difference around 9 PSI
A drinking straw does not work very well if you put a hole in the side
The gasses stay in the pipe and condense out dripping oil into the intake manifold
  • Like
Reactions: irc
Description of operation from ELearn is not very detailed but it does give an overview.
Blow-by and other gaseous fumes are sucked through the small part of the pipe at idle, and the large part when throttle is open.
Anyway, off to do more Christmas things now, so...
Have a good Christmas, everyone.
