Technical  Engine Problem?
Sorry ladz, coil pack is gone.. the 2nd cylinder is absolutely not sparking, must replace with new one.. I was changing all the leads between them, and finally one outlet of first coilpack is not woking.. my stupidity that I didn't find out earlier..but, I've got new leads and sparks, and the leads was also gone as well.so maybe it will be fixed finally - another problem - should be 2nd cylinder not running a reason for idling and cutouts in higher temps ?????
or maybe next owner will find out, Iam already fed up from "Fix It Another Time" for a long time.. :yuck:
fingers99 said:
Difficult to say -- some SPI engines have a flat spot (at what revs does this happen) although mine doesn't. And the ECU does take some time to re-learn. I'd initially suspect the airfilter.
I don't know exactly, around 3k i think.. it's not serious, just a small "kickback" :p
airfilter is allright
