**Engine problem - URGENT HELP REQUIRED!!!**
Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Just out of curiousity is the £400 for the pair of cams, or just the one? (Would i need to replace both?)
Daz
Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Took the rocker cover off (that was hard enough...lol), can't see anything obvious...
Drained the oil, and ran it through a collinder (don't tell the mother-in-law :)), pretty clean...
I looked for any scratches on the cams...(none)
Turned the engine over manually...(all seems fine)
I did notice one of the spark plugs was a little bit rusty...
Is there anything else i can check easily?
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Looks happy enough. Rusty ontop of the plug or did you take them out?
Its always possible the variator has bitten the dust, you know how often the barch ones die :)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Looks like its just on top...but i haven't taken them out yet, going to do that in a min. when i warm up a bit...lol
How much would a variator be?
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Not a clue. Isn't the symptom on the barch a rattly top end?
Oi! Nige!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
on the punto or barchetta, it usually makes the car sound like a tractor.
i think the barchetta club websit has a soundfile if you want to compare.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
You wouldnt know the URL for the barch site?
Daz
before replacement, www.fiatbarchetta.com/misc/before.wav
after,
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
Sound uncanningly (if there is such a word) similar!
It looks easy to replace (but looks expensive)
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
i dont think its expensive as a part, its just the fitting cost.
Had your cambelt done yet Daz?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise cant
erm...no :(
was planning to get it done at the next service...
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise can
I can't find the bloody thing on the Fiat parts CD, are you sure my car has one...lol
If anyone has the parts CD, could you see if you could find it for me...
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of noise
anybody? :(
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation of n
I aint no mechanic but it don't sound to healthy does it
Speersy
It must have one as its variable valve timing.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: And expalnation
I think the Variators are around £70ish...
Funny cause a few months ago, I had a noise problem similar to yours Daz..Took it to various garages including 3 Fiat dealers, and had various answers...one was the variator, only turns out that the Brava 1.8 hasn't got one, but the 1.8 Barchetta has..
anyway the problem was diagnosed as inlet cam/tappets/piston slap/ and finally bigend! which it turns out it was...
bought some Millitec 1 (I know it was slated on here) but drove the car on for around 3000 miles, and was still going strong until I got hold of a second hand lump, which is being fitted this weekend
Re: ...
Right, i dont think its the variator, as it doesnt stop when revved over 2000rpm...i only tried this once as i don't want wreck anything else...
Come on peeps...HELP ME! :)
Daz
Re: Re: ...
talk to Sy nicely and see if he will lend you the one off his non-running HGT to try ;) u and tafi could go on a road trip to get it to try. lol
I
2
1K
Dark Lurker
W
922
wakka
W
A
5
636
M
890
David
