brava1.4
Hi, I have a Brava 1.4 1998.
Can a faulty rear engine mounting cause problems when pulling away in first gear, i.e shuddering, jumping etc. But cause no further problems when driving in general. As the problem only happens when you pull away from rest, or when you use the clutch peddle in traffic (you keep pressing and releasing the peddle).
Is there a way I can test the rear engine mounting?
If it needs replacing, how much will the part cost?
thanks
thanks
