Technical Engine mount bolt torque
I need to replace the two engine mounts on the bottom of my engine (1.9 jtd). The two square looking ones. Looks easy enough but I don't have access to e-learn at the moment. Is anyone able to screen print the relevant pages or send me a copy of them so I can get the correct tightning torques on the bolts.
Also I assume its just a case of taking the engine weight on a jack/stand and then unbolting and replacing? And theres no worry in reusing the old bolt is there, I know sometimes people say you should change them but if it comes out ok it will surely be fine?
Thank you in advance!
Nuts and bolts securing the reaction rods to the engine and gearbox are 7.5 daNm.
Bolts securing the reaction rods to the suspension cross beam are 13.5 daNm.
So i'm back! This time its the gearbox mount. I've got elearn back but half the pictures don't work and i'm not one hundred percent sure i'm looking in the right section so I just want to check.
For the nut that holds the gearbox in the mount is it 8 daNm and for the bolts holding the mount to the car is it 5 daNm?
Thanks in advance
