I have an ongoing issue with my 2017 Fiat Tipo 1.4 TJet. I have posted previously but unfortunately the problem persists. After each fix which is coupled with a reset of the error code, the engine management light comes back on after about 100 miles and the stop/start stops working. The engine management code is P2195 which indicates an issue with the oxygen sensor. Both lamda sensors have been changed, perished breather pipes replaced and vaccum leaks checked for resulting in an o ring being replaced. The main dealer says the only thing left for them to do is change the Cat and quoted £2.5k - the emissions are perfect though. Any help/ideas appreciated.
