Technical  Engine management light
Kevin goss
Hi
I have had problems with my idea 1.4 2005... Went to start and it comes up to high temperature.... So replaced the system and engine management light is on..... All oil and water level are right....
Nothing on the code reader.... All codes cleared..... Now airbag failure mmm now on ��...
It could be a poor connection..low voltage at sensor issue.
Best to get it plugged in for fault diagnosis.
In some respects the Airbag light is a good thing..as it may well give a 'less vague'
Error code then the P code of an engine warning.
Charlie . Cardiff : Oxford
Just check voltage this morning it was only 11.5v went to start it the fuel pump was like it was starting and stopping and it seem like a clicking sound under bonnet when the key was turned on .....the battery went down to 9.6v when I turned the key to start..... So I am thinking it time for a new battery????
Did the battery do the job..??
Hi seems to better okay and starts okay .... Just got air bag light on now ��
