- Joined
- Nov 6, 2008
- Messages
- 65
- Points
- 30
Hi
I have a 1998 1.2 8v Punto that the engine has just cut out and can not restart.
It started fine pulled away normal got about 30 foot then it was like the ignition had been turned off this was instant no misfire or juddering just cut dead, all the electrics i.e. lights, wipers etc seem to work o.k..
The engine turns over fast, petrol is being pumped to the injector as can see moisture after turning engine over, tested the high amp fuses under bonnet all good, changed crank shaft sensor about 4 years back so hope that is good, wiring to it looks o.k.
Not tested if spark at plugs as need to get a plug socket to remove plug ... not sure what size socket to get ... please any info on socket size, thanks.
There is no attempt to fire on any cylinder at all ... does this happen if the coil packs have a problem ? is there a common failure to look for that affects all coil packs.
Any advice please, thanks.
