levets
Sorted the issue with the thermostat housing, bled the system on an incline as per the guide on here. Just coolant coming out of the bleed valves... but radiator staying cold even though top & bottom hoses hot. Fan coming on as normal.... Also heater blowing cold only.
Is it likely that the radiator IS knackered? Is it worth trying to clean it out (flush) or would it be better to replace with a new one, bearing in mind I still have to take the radiator out and put it back... still might be knackered?
any other suggestions?
