Technical  "Engine failure"
Hull
At least that's what the dash says.
Car drives fine. Rad kicks in and has oil etc.
I was doing 60 when it popped up and I carried on.
This is the first time in a while that I've done a constant fast speed and I do have a hole in the backbox. But it's obviously past all the sensors.
I take it the engine check light
Rad kicks in, you mean the fans did they come on full at the same time as the engine check light came on
Is your car strugling to get to the the half way temperature by any chance
I am guessing the light came on while coasting
I suspect the rubber seal in the thermostat has perished
It's pretty easy to check with a cold engine
If you haven't got a code read it will clear after 5 good starts or is it 10
Got a thermostat for £9 odd free delivery.
I was gonna do the job at work, just in case I had issues and had to stop off at B&Q, so I'm at the till and it's snowing like crazy and I have no heater. 😢
I had to remove the ecu....................
Anyway, the old thermostat was welded to the hose, I didn't want to rip a hole in that. So asked for help at work. He used a tiny screwdriver and duck oil.
Got it all back together, turned the key and it cranked and cranked and cranked.
The two ecu connector blocks are self seating/locking. But that's the only thing I touched. So I unplug them. Blow into them like a Mega drive cartridge and it fired up straight away.
It bled easily enough and I now have a heater. 🥵
For anyone reading this later, you don't have to disconnect these blocks; it's possible to leave them connected and just swing the associated parts out of the way.
