Hi all, hope someone can help, I have just registered on this forum to help diagnose what is wrong with my Mums fiat Panda 2009. The issue is that it appears to intermittently stall, but strangely it seems only when the temp needle is below half way, so it runs fine when engine is warm. Starting from cold is no problem but after 4-5 mins of driving is often stalls. The battery is good.
My mum took it to garage and they checked it out, said it was a cambelt issue, so they replaced that (It likely did need replacing anyway as its done over 90K miles), and said its running fine and gave it back, but the issue persists. Then my Brother took it to another garage and asked them to clean out the throttle body, as someone told him that would fix the issue, but the issue still persists. Yesterday I replaced all the spark plugs, and all the HT leads, checked the two coil packs with a multimeter (both reading within spec), but again the issue still persists. The EML is not flashing up, and a quick scan with my cheapish reader reveals no pending codes, although there is x1 stored code (PO115,Engine Coolant Temperature (ECT) Sensor Circuit Malfunction).
Anyone have any ideas ? So far we have
Replaced cambelt (garage used a cambelt kit)
Cleaned soot from inlet manifold
Replaced Spark plugs
Replaced HT spark plug leads
Checked both the coil packs primary & secondary resistances (both readings are within spec)
Thanks for any help, the garages can find nothing wrong !!
- Model
- Panda
- Year
- 2009
- Mileage
- 90000
