Hello everyone. I`m new here so be gently (just kidding)
I own a `95 Tempra SX from 2 years ago and i didnt had any troubles with it until recently when encountered difficulties to start my engine in the morning. It takes 5 to 10 seconds to start it ..sometimes i need to give 3-4 tries to start it. After this i can start it without a problem(tested). After the engine becomes hot, if i leave it for 30 min i encounter the same problem even if outside are 25 degrees and engine coolant still has 60-70 degrees. I dont want winter to catch me like this because i will need a store of batteries and a new starter to pass the winter. I dont know if the fuel system has a one way valve to prevent gasoline going back in the tank, but in the car`s manual it says that if you need to work on the fuel system you need to take out the fuel pump relay so that the gasoline from the system will go back in the tank which means that there is no one way valve. Only valve which i know is there is the electro-mechanic one which cuts off the fuel if the car is stolen, or crashed.
Well i hope someone can help me or give me some ideas.
I thank you in advance !
