Hi all. (again)
Those who may of seen my past problems with water pump and flashing engine light, hopefully can shine a light on this issue for me?.
Ok.... 1st of all, i am yet to strip the car down again to double check the timing after reading a p0300 code.
BUT, when i went to have a look at this a week ago i found my EML had turned itself off and no mater how hard i tried i could not get it to flash or go solid.
Chuffed with this i drove to work and had NO issues at all with the car's running etc.
Put 1/2 a tank of fuel in it and the EML started flash at me while giving it the beans and letting off the gas then going solid.
Feeling fed up and not being bothered to have a look at it again with this pants weather.
I ignored it, the car drives, revs exactly as a "normal" car should run.
Anyhow, today while trudging slowly through the snow to work the EML once again turns off by itself and again no flashing under revs etc.
The 2 similar things are that both times the fuel was almost out.
Whats going??
And once i added 1/2 a tank the light flashed again.
Whats going??
