General Electronic toll tag with 500?
Cornwall
Anybody use an Electronic toll tag with 500? The reason i ask this is i use one for the Tamar Bridge on the commute to work and i have had lots of problems with the positioning of it on the windscreen so the system on the payment booths could read it. My previous car a Renault Laguna had some special windscreen glass which prevented the bridge toll system seeing the tag unless it was in a special position on the screen.
Renno's have a specific coating on their windscreens which you'll see if you wear polarised sunglasses (as I do) and the 500 doesn't. But it does have heat reflecting windows so you might be out of luck :p
Does it? They don't work very well!
Cars with heat reflective windscreens usually have a point where there's no coating for this reason. I have a Citroen, the point is directly behind the rear view mirror, if that helps.
Believe me they do work well :) The wifes Subaru doesn't have heat reflecting anything and compared to the 500 it's an oven on a sunny summers day but the 500 is very very cool in comparison.
I can see the coating without sunglasses. Maybe I've got polarised corneas?
