Hi have a look at this link re the well known rear hatch wiring issue not the Maybiline link
I have a feeling however that these particular electrical problems have the potential to a real pain in the backside if not addressed. You really do need to have this fixed(hatch wiring) before you end up with the "Christmas tree" of lights on the dash which can sometimes then break more...
www.fiatforum.com
Also try turning on the Day running Lights use the Menu button on the dash and the up down to access the option, first try starting the car
lights off and see if the bumper lights are on? It will probably need a new bulb, replace both type 580.
It
will need a new engine earth cable too about £5 from Ebay simple to fit, 300mm long 8mm holes
When was the cam belt replaced?
Upgrade bulbs in the headlights are an option like Phillips Extreme H7
Understand the Bluetooth is pants
Have the AC
recharged regardless of whether it works and a new cabin filter( PITA to replace ) and leave the AC on all the time!
Iridium spark plugs a sensible replacement fit and forget, almost,,
It will probably need some suspension TLC
As its for your daughter consider a new battery
Parts are cheap and straightforward to replace IF you can do it yourself
You didn't mention the flashing mileage this could indicate a failed Bluetooth module other computer related issue hook up to a laptop to fix, what message comes up at start up as the warning triangle is on, could be a bulb failure
