So after i put my new engine on (650cc) every time i am turn the switch to off to kill the engine i got the gen and oil light on. The when i remove the key those two lights get brighter and stay on:bang:. If i crank the starter (without the key in) for a sec, just a little crank to draw some current, both lights goes off and there is no current between battery and chassis so there is no leak.
Gearbox as well as engine are grounded with a jumper as they were before.
I touched a cable between engine head and chassis When those lights where on but nothing changed.
If i jump the engine head with coil's black wire those lights get even brighter. (i am using a powerspark ignition without capacitor).
In the diagram bellow you can see my connections before and after.
