Technical Electric window problem
sladedestiny
Hi.I have just joined the forum.My wife has a P reg punto. However the passenger side(front) electric window does not work and I can't seem to find any fuse box markings that indicate supply to the windows. Can anyone advise? Thanks in Advance.
The electronic windows on Mk1 Puntos are rubbish!
And its always the passenger one that starts going slow and then stops working altogether!
Its probably the case that the motor has stopped working so you will need to try and source a working one to replace it with.
Its easy enough to swap them over, its just a bit fiddly!
