General Electric diagram???
Fishman6
From where can be found
electric diagram
Fiat Ducato 14
( year model 1987) Sofim 2,5 Liter Diesel
(PDF -format) :cry: ??
tootaylo
hi, cant help you with that but i was wondering if your engine is the same as mine. 2.5D 1990? was wondering if you know what compression ratio and pressure readings should be, just had comprsn test done the garage dont know waht readings should be!!!!! cheers
PeterM
Black Rock VIC
IF this helps, data I have from a 2002 manual says compression ratios are:
1997 JTD = 17.6+/- 1.7
2300 JTD 16v = 19
2800 JTD = 18
Peter
tootaylo
cheers peter, the comprsn for my van was 28, 28, 27 and 30 the garage said they think they are within the normal parameters so guess they must be!
t
