General  eLearn Manual - help
PeterPanda
North Kent
Hello gang
OK, downloaded the eLearn manual (rar), unzipped all files, run the setup installer, however the shortcut then fires up a prompt to insert CD-ROM (in Italian)
So I think the program expects the manual data to be on a separate CD instead of on the hard disk.
Has anyone run this recently or can explain the easiest / best way to use the manual?
I would prefer to have all the files on my HDD.
Thanks in anticipation
PeterPanda
I bought a CD off ebay and found that though it put a lot of files on the HDD it always wanted the CD in the tray to run. A pain as mostly I use a netbook with no extl drive.
i too would like a way round this though truthfully I found the information of little use nothing like a Haynes manual.
Hello gang
PeterPanda
For all eLEARN manuals, only the user interface is installed onto the computer. The CD needs to be in the drive whenever you want to use it. This way, the desktop icon will be the same for whichever model eLEARN disc you want to use. eLEARN was originally designed for dealers that would have discs for all models.
Only way round this is to instal it on a virtual drive.
There is no Haynes manual for the Stilo. :confused:
OK Davren, thanks - so once the main rar is unzipped, should all those files be burnt to cd, then the installer run from there?
Yes.... the RAR file will unzip to a file named "Fiat Nuova Panda.iso". Double click that file and it should open whatever CD burning program you have and burn it to a blank CD. Install the eLEARN interface by double clicking the "setup.exe" file from the CD.
The easy way to have the manual on your pc is....
Download a virtual CD drive from
microsoft web site
Mount the .iso file on the virtual CD drive
Then the program views the virtual CD drive as if it was a real cd.
Great for netbooks that don't have a cd drive.
There are other free virtual drives, 'magic ISO' and 'Daemon tools' to name two.
h i...do di i have to learn italian too or can i get an English one. for a doblo van
thanks for that , last thing: i assume then its like a pdf [images on screen]. and is it a workshop manual [how to do all jobs on a doblo. and does it cover 2007 1400 cc
thanks
thanks
It shows images, but they are not in PDF format.
It's the workshop manual designed to assist Fiat workshop mechanics, so it doesn't describe every step to complete a task.
This thread relates to the Panda (Mk3) eLearn manual. You would need the Doblo version of it for a Doblo.
.. cant figure out what to do on the page . looked again , looks very useful thanx for finding it , but what does "da 12/03" mean in the selected box . i need to select the year which is 2007
thanks
ok i see... looks like the one for my van ....great that i havent had to go the other route to get the manual. thanx again
thanks
Depend what you want to use it for
Most useful things are after you click
On the blue link on the left hand side
Removal-and-Installation
Play around
Torque setting
Engine codes
Common faults
Circuit diagrams
And so on are all in there, just takes a bit of finding
The more you play with it the easier it becomes
It is a little frustrating to start with
Just posting some more info as I have also been using eLearn and had trouble with the "Insert CD" error. Basically after installation and running eLearn.exe from whatever folder you installed it to, it reads the location of databases on the CD ROM using \Database\eLearnHD.dat in the installation folder. This file is actually an MS Access database with hardcoded references that link to the CD ROM folder \Database\eLearn_x.dat where x is any of the databases. In my case it is hardcoded to E:\ but I am not sure whether this is the same for every installation - check eLearn.log if it's not recognising your disc and you will see which drive letter it is trying and failing to access. In my case it will only recognise the CD ROM files if they are mounted at E:\. If you want to run the program you have three options:
(1) Burn the files to a CD, insert the CD into a drive assigned to whatever letter shows up in eLearn.log
(2) Mount the .ISO file as a virtual disk assigned to whatever letter shows up in eLearn.log
(3) The location of the CD is stored in a regkey called cdPath at Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\eLearn (or Computer\HKEY_LOCAL_MACHINE\SOFTWARE\eLearn if you are on an older 32-bit system). If you extract the CD ROM/ISO files to somewhere on your hard drive (eg C:\MyDirectory\) then change the contents of this regkey to C:\MyDirectory\ and it will work. Note the last \ has to be there or you will continue to get the insert CD ROM error.
