Good morning and greetings from Greece.
I own a Panda 1.2, 8v, EMOTION. The car has been operating without any issues since 2018, when I bought it. Last December, after replacing the clutch kit (I mention this because I’m not sure if it’s related or just a coincidence), the car started showing errors in the ESP and Hill Assist systems, as well as in the power steering. However, the steering itself works normally.
The other systems do not function, and the warning indicators appear on the dashboard. Over the past week, the airbag warning lights have also started to come on, either when I start the car or while driving. However, the issue is not constant — there can be days without any warnings. Most of the time, though, all the warnings appear, roughly 7 out of 10 days.
I also noticed that moisture gets inside the passenger-side headlight. When it dries out, the frequency of the errors decreases significantly. However, in that same headlight, the W5W bulb has burned out — I mention this in case it could be affecting or disturbing the CAN system. Also, inside the headlight, I have noticed that the wiring appears to be significantly deteriorated.
I should also mention that the battery is new and was replaced one month before the problems started. Another observation was that there was heavy corrosion on the negative terminal, so I replaced it with a new one, as the original had become loose over time.
I measured with a multimeter, with the engine off : 12.3–12.5V, and when engine running: 13.9–14V.
In MultiECUScan, I am getting a Body Computer error U1602, which I am unable to clear.
I should also add that twice I have received an ECU error related to the lambda (oxygen) sensor. I saw a video on YouTube suggesting that U1602 could sometimes be a “ghost error,” but with the dashboard lighting up like a Christmas tree, I don’t think this leaves much room for it being just a ghost error.
I apologize for the long post — I’m providing as much information as possible in order to get some help, as at a workshop the likely answer would be to replace the Body Computer… which might be true… or maybe not.
Thank you in advance.
- Model
- Panda 1.2, 8v, EMOTION
- Year
- 2005
- Mileage
- 205000
