multieddie
I've got to share the experience my Multi has given me today.
I picked up a 2003 JTD 115 about a month ago and am smitten with the looks, practicality and sheer nerve of the vehicle. Being a 6 year old car there are a few niggling faults here and there. The anti roll bar link rods need doing (knocking from the front driver's side) and it's always been a little down on power. I have also experienced the Engine Control Faulty warning light a few times.
I replaced the MAF about a week ago after running with the old MAF unplugged from a few weeks (a smoky but potent experience).
When I plugged in the new MAF, the sluggish performance that had led me to unplug the MAF in the first place returned.
Annoyed I persevered and after a few 'floor it in 2nd gear' moments, I got more more power from the car, but it still wasn't right.
A quick poke around on the the forum suggested EGR issues, so today I decided to grab a can of Wynns Carb Cleaner and do battle with the EGR.
I did as one forum member has suggested and tried to split the EGR in situ. However a rounded off 4mm Allen bolt on the solenoid halted my progress. I couldn't get the solenoid off and therefore couldn't give the innards of the EGR a good clean.
So I hastily reassembled the EGR, as I had to pick up the kids and take them bowling. However, nothing could prepare me for the abysmal performance I was about to experience. Inadvertantly, I had got the EGR stuck fully open. Meaning that rice pudding skins within a 10 mile radius of my Ugly Bug were feeling pretty safe and smug. My car was so gutless I could have cried. What had I done? I was forced to brave a stressful journey home out of Liverpool city centre, with hordes of baying drivers snapping at the heels of my stricken sickly wilderbeest of a car...
Safely home (and now in the grip of a biblical rainstorm) I resolved to fix the problem. I donnned my waterproof and the steeliest Clint Eastwood look I could muster, and popped the bonnet, ready to give that EGR a right good going over.
And boy o boy is the EGR a swine to get off. Secured by 7 of the least accessible bolts known to humankind. 1/8 of a turn on each bolt if you're lucky meant a length removal process.
However, eventually, after an hour of cussing and chronic backache I had the EGR in my hand. As soon as the unit was out of the car, the problem was clear. After 70000 miles of use, the soot had completely jammed the valve.
So I grabbed a toothbrush in one hand and a can of carb cleaner in the other and within minutes the valve was opening and closing happily with finger pressure. The black furry innards of the valve had made way to shiny metal and a reassuring spring in the valve's step.
I put everything back together plugged in the EGR and the MAP sensor cable and secured the engine cover. All that was left was the test drive...
The result? Awesome. Just Awesome. I went from crawling away from the lights with queues of disgruntled drivers frothing at the mouth behind me, to spinning wheels off the line and beating chavs in Golf TDIs.
The moral of the story. If your Mutli JTD is feeling asthmatic, suspect the EGR - but for goodness sake, don't do what I did - give yourself plenty of time and do the job properly.
Thanks to all the former posters on EGR troubles - your postings have saved me hundreds of pounds.
