Technical duralogic problem 500 lounge 0.9T 2014
cabmerlot
tasmania
hi guys and dolls
hope im in the correct section
i recently bought a 2014 fiat 500 lounge (0.9 turbo twin air)with a couple of problems
first it gets no gears....it will click over to auto and the hydraulics prime when the door is opened
second the engine is giving a really loud screech when running.......it sounds like a bearing somewhere....when i rev the engine it will hold screech and then will stop after it reaches revs
so i was thinking serpentine belt/pulleys
so to access the belt i pulled the charge air pipe off(from the top) and found a pinched O ring into the throttle body
the serpentine belt looks due for replacement but the functions and idler bearings all looked fine...one idler roller did have some rubber build up on it tho
also checked the hyd oil and found it was on the mark
after that i found it easier to access belt from below
there are no codes(that i can see)
multiECU scan dont post to australia
tomorrow i will refit the top pipes with repaired O ring then run engine with the serpentine belt OFF
then fit up belt and run again(using old belt while awaiting new belt)
i dont know the history of the faults as orig owner was Chinese and not much good with English but he said a mechanic told him it needs a complete new gearbox
heres what i am hoping.....the screeching was caused by compressed air from the turbo leaking out from trapped O ring......the ecu dosent like low air pressure so has decided to put the car into (no-go mode)....
will find out more tomorrow
russ
Model
fiat 500 lounge
Year
2014
Mileage
50000
well the screeching wasnt caused by o'ring or serpentine belt so i now suspect clutch or gearbox...have ordered a new clutch but am a little busy atm to be pulling the box....also have just ordered multiscan so cant do much til that arrives
russ
Hi Russ, sorry you've not had responses yet.
You might be in the wrong section, I understand your car is a 500C? You might be better off here: https://www.fiatforum.com/forums/500-2007.148/
There's a dedicated thread to DuaLogic faults you might find helpful here: https://www.fiatforum.com/threads/the-one-and-only-dualogic-failure-thread.425006/
Gearboxes are fairly problem free (although DuaLogic can be hard on clutch), it's the separate hydraulic actuator that bolts on top of the box that causes most of the problems, often due to failing seals.
Some brave souls have rebuilt them. https://www.fiatforum.com/threads/t...ic-failure-thread.425006/page-37#post-4667877
Specialists prepared to take them on are few and far between.
Needs its own dedicated hydraulic fluid.
Must admit I'm not sure if your thread title is meant as a joke... 'Dura' it certainly ain't :D And the 'Logic' part is debatable too.
Hi cabmerlot (Russ)
Did you ever get your problem sorted ? I have the exact same symptoms, loud screeching, stops after reaching revs, no gears etc. Also had a pinched O-ring in the throttle body....can you believe it !!
I flushed the gearbox DuaLogic hydraulic actuator twice when I purchased my 2013 Fiat 500 0.9l Lounge (85K) to try and avoid future problems although there were no issues with it at the time. And I helped out another Fiat 500L owner whose Fiat had refused to change gears on the local motorway. We flushed the DuaLogic actuator and with new hydraulic fluid it operated smoothly.
Re MultiECUscan, I imported a licensed version from Gendan in the UK via a relative in Northern Ireland as Gendan didn't export to Aus at that time. The software was very useful for sorting a Bluetooth issue but no use in diagnosing the one I have at the moment.
However, I suspect this time it could be a clutch plate throw out bearing given the level of noise. I'll be towing it up to the Quickjack hoist in the shed next week to have a closer look. Any feedback on how you resolved your issue would be greatly appreciated.
