Technical Ducato water temp going to 1/2 immediatly
spider1
Cambridgeshire
Hi All,
Couple of questions, where on a fiat ducato 1.9 I would find the water temperature sensor (I have had a fairly good look but still can't see anything), also a part number to replace it.
Thanks for you help
Ian
Hi SPIDER 1
I have a 2.8 so can only suggest from how mine is laid out. On mine it is on the n/s of the engine, there is an alluminium block at the end of the cylinder head with the top radiator hose and two temperature sensors.
Also check out my reply to this question regarding the heater matrix and other problems.
radiathttps://www.fiatforum.com/ducato/191903-dashboard-removal-heater-matrix.html?highlight=mythingors etc
I would suggest you will need a new radiator.
Good luck
MYTHING
Was told to do this first and it worked, turn ignition on, remove the centre plug from the instrucment cluster, wait 5 seconds, replace the plug and turn the ignition off then back on.
Worked for me :)
Many thanks to those who replied.
Ian
