Fredastaire
- Joined
- Dec 19, 2017
- Messages
- 276
- Points
- 100
I have a March 2017 Ducato L2H2 nearly converted to a Campervan. I need help for the rear power socket, (not factory installed at purchase). The factory wiring is all there, the applicable fuse F09 is in the engine bay fusebox. Ive added a rear cigarette lighter socket to the factory wiring however its dead. Ive removed the RH driver step panel, found the yellow wire, proved electrically that its the one to the rear and its electrically dead, (no voltage ign on or off; no Ohms resistance to chassis).
I dont have and cannot find a wiring diagram, I am assuming that either there is a relay missing or its not switched on by the Canbus. The handbook shows all the fuses listed however although relays are shown, it doesnt identify the relays at all.
If I can find out which relay it is and where then i'm wondering about removing the relay and putting a jumper wire across the main spades.
Please can anybody help?
