Try entering your vin number into eper and seeing what that oar number is of your head
Then look see if is fitted to a later van
They are looking at EARLIER
for better availability and cost![]()
quick answer ...Hello,
I´m looking for some info about differences in JTD engines, especialy 2.3 JTD.
I have 2006 ducato - eu4 with bad block and (valve drop inside). Can I use block or head from pre 2006 (eu3)? They are much cheaper here.
Thanks !
quick answer ...
I wouldn't expect so.
2.3 is a different size to 2.8.
I would expect the bore diameter to be different.
Then the head and valves expected to be different.
This is just a experienced guess.
However...let us all know from your research.
Or you thnking of a complete engine swap?
Understand what you say about high miles used engines.I can buy used head or repair my if it will be possible. Head is not the main problem.
I will buy new piston, rod etc. but I need to have good block. And that´s the problem. Used engines here are like 400+km with questionable condition and extreme price regard to price of the whole car.
PS. I cannot load eper. Is there anything similar ?
