W
While it is just possible that the vehicle is a late registration 2001 model, with either 2.8D, or 2.8idTD engines, I assume that it is in fact a 2.8jtd, with electronic injection control.
The symptoms described could be caused by leaking injector(s). These would cause the engine to struggle to achieve minimum common rail pressure at cranking speed. Once started the greater engine rpm facilitates achievement of the necessary pressure, and the engine runs without problem.
"Edit. Another possibility for poor starting on a 2.8jtd engine is a failing camshaft position sensor. The ECU uses the camshaft (timing) sensor to determine the stroke, whether compression or exhaust only when starting, and subsequently relies only upon the crankshaft sensor. This would explain poor starting, but not starting and failing to continue running."
An injector leak off test will confirm the hypothesis. A leak off test is carried out by diverting the injector return pipes into a set of four bottles, one for each injector. On cranking the engine, the bottles should fill at equal rates any a faulty injector will fill the bottle at a greater rate.
Sorry, but to avoid confusion, with the OP searching for a non existent earth strap, the problems with the engine earth strap described above, do not apply to the OP's x244? model.
