General  Ducato code problem
Status
Not open for further replies.
ducato code
have a ducato motor home.
changed battery and code light appeared.
have trid red key but cant get this to go off.
is there a special sequence.
help please
e holt
Re: Dicato code problem
But its there for a reason as a security measure.Most ducato code problems are due to the code box itself.
is the code box yellow just behind dash alongside steerin column to the rite
Cheers Chickiboy1
I've just found a local diesel pump services who will take out the anti theft unit in the pump and enable a normal stop solenoid.They said they will test it as well for £170+vat.
I've given up finding the ECU, dashboard partially out, carpets up, panels undone, the Pump looks the best option now.
Thanks for your help!!
Simon
hi simon,
don't know if yrs is in the same position the way fiat swop & change all time but my ecu is in engine bay above battery..
Ah yes Simon, I have bypassed my pump. Only the other day as became unreliable again.
Just a note though, it did not involve smashing anything off, just pryed off the lid. The circuit board is mounted in silicon so scrapped it off and cut the middle wire and soldered in a piece to the soleniod. Re set the board in neutral cure silicon and popped the lid back. Now 100%
Only thing I wished I had done, Not cut the middle wire just bared the insulation and soldered the new wire to it. I have a feeling this would prevent the code light comming on.
Ah well next time.
hi new kid, just take de bulb owt de clocks mon
Can anyone clarify if this will work on later ducatos? If so upto what date?
hi new member ,(joined last year first time iv written) iv bypassed many of these code systems .3 pin plug going to code control unit @ rear of pump unplug - smash of control unit (dont damage solinoid behind control unit) need to remove 2x shear bolts that secure control unit use vice grips once removed check which wire @ 3pin plug you disconected is the ignition supply (sure its middle) solder to the wire on top of solinoid , tape up 2 exposed wires left over , now disconect ( large plug on code box next to steering coloum yellow-green or black in colour depending on year produced this stopes code light from coming on) van shall now start but you dont have an imobbilizer , dont pay any more than £200 for this to be done thats what i charge thats my knowllage included in that well now iv told you all you can save loads and do it yourself good luck .......
hi there can you please tell me if this will work on a fiat ducato 14 W weg 2000 1.9 d as i have the same problem and i can get my head around it.
if you colud let me know how to bypass the codes that what be great
many thanks
jason
I have the same problem with my van i have reset sensor but still have key code error up. I have the red key but unable to get the reset patten from fiat.
So i want to bypass. Can someone email me with what i need to do.
Status
