Hi, Bonjour Steve,
I have experienced similar symptoms (gearbox hydraulic pump would intermittently fail, then after a period (of cooling?) it would temporarily resume operation). This is a very tricky fault as “Gears not available” indicates on the dashboard display and it renders the vehicle immovable under its own power (very embarrassing at a big intersection). Using my diagnostic scan tool I could see the relay function and gearbox hydraulic pump cycling every 2/3 gear changes (boosting hydraulic pressure from low limit of 36 up to 46 bar). When the fault occurred, the pump failed to reboost hydraulic pressure and the pressure dissipates below 35 bar (dashboard “no gears available” warning illuminates).
With this diagnosis, my local Fiat Professional dealer quickly misdiagnosed the fault, saying they’ve seen it many times, and strongly recommended replacement of the clutch master cylinder, clutch and dual mass flywheel for a cool $14k! I walked away, determined to fix it myself.
I confirmed the faulty 12v pump motor by initially confirming both relay and 30 amp (green) fuse serviceability (I replaced them with new for $55, just in case there was an intermittent fault), then tried bypassing the 12v wiring loom with a dummy supply wire. Then again the gearbox worked perfectly for 40 gear changes then bingo, same “no gears available”. Based upon this I ordered a new pump and accumulator (accumulator was changed due to relative cheap price, gained access and importance for offloading the hydraulic pump mechanism).
I ordered pump and accumulator (received in 5 days to NZ!) from this excellent German part supplier
https://www.sequparts.com/product-c...MI3MK7xJDxkQMVHs4WBR34GDcFEAAYASAAEgJJmPD_BwE
To change the pump I first placed the van on highest levelling blocks under the front wheels (you need to gain 125mm) and safeguarded the van from unwanted movement with chocks and axle stands. Remove the battery and battery box in the cab (easy 20 minute job).
Then whilst under the van but using the battery box hole for extra arm articulation space and a far less claustrophobic environment. Vitally I used a Kingchrome mini T20 Torx ratchet ($23 for a set and this tool - or similar micro Torx ratchet- is essential due to confined space around the pump motor. This ratchet is about 3.5” long and fits any bit).
For further access, I removed the single wire electrical plug from the 12v motor, and the multi wire plug from the adjacent hydraulic pressure sensor, I also removed one of the DPF sensors for better access (this will become obvious when you’re under the van).
Then using the T20 mini ratchet you need to undo the 3 short screws (two are diametrically opposed, whilst the other is the pump earth connection) that hold the 12v pump to the gearbox hydraulic power pack. This is easily achieved by methodically working in an uncomfortable but very doable position for anyone who considers themselves a competent vehicle DIYer (i.e. confident in performing oil changes, brake pads replacement etc). Take care to keep the screws captive in the T20 bit until recovered in your hands, as dropping them could waste valuable time. Once al, three screws are removed, get from under and have a cup of tea, before the important second half begins! The reason for this break becomes evident as the pump can only be extracted in a certain position and angle, once you find this it’s voila! Do not be impatient and risk damaging anything (you’re working directly under the LPEGR Valve) keep logically trying different positions until you find the angle, then try to commit it to memory lol.
Now out you can compare the parts, noting the new one is exactly the same. At this point ensure you rotate the new pump’s oblong shaped drive, to the ‘same position/angle’ as the removed one! This one simple task can save you lots of heartache.
Then in the infamous Haines Manual speak: refitting is the opposite of removal.
Consider ensuring the mating face is clean and clear by wiping with a clean cloth and refit. When installing the screws, to prevent dropping them, I doubled over a 10” strip of electrical insulation tape and punched a hole in the end for the T20 screw thread. The idea here is to prevent inadvertent loss of the screw and avoid drama, as if you drop the screw - you just gently pull on the tape and recover it and start again. Then once the thread is safely engaged a few turns (due to the confined space the micro ratchet will tighten one click at a time), you can pull the tape off the screw and discard it. Loosely engage all three screws, remove all the retrieval tape, then torque the 3 screws evenly (to ensure the pump is fitted flush) to two white knuckles (good luck getting a torque wrench in there!).
If you’re still with me, and thinking this sounds tricky, it is. BUT BE ASSURED I REMOVED AND REPLACED THE PUMP IN ABOUT 1 HOUR (2 hours including start to finish and test drive). You can do this.
I now believe this is a symptom of water ingress from the infamous Ducato scuttle area which tracks down and sits around the gearbox hydraulic pump earth connection……but this is only reasonable suspicion, based upon the corrosion present in that area despite the pump having a galvanised body. My Ducato 290 van is 2017 and 21,000 km, but had scuttle leak evident in engine bay when I bought it.
Finally, it’s also important to separately replace the fluid of the gearbox hydraulic system (Penrite LDAS) and clutch mechanism (Dot 4) a few times. These fluids go largely unchecked and never replaced but can get contaminated and cause wear. For these you’ll need diagnostic gear to perform clutch maintenance tasks like bleeding and calibration (certainly worth buying for a few hundred dollars and keep away from the dealers!). But note, this is a separate concern to the described intermittent fault on the Comfortmatic gearbox 12v pump.
