Hi all,
I started a thread on 'Newbie' section yesterday as my 2009 Fiat Ducato motorhome 2.3 M-Jet wouldn't start after being laid up since February. I came to start it and found battery was flat but was going into hospital so didn't charge for several weeks and after charging last weekend found it would not start. I searched the forums looking for ideas as engine was cranking but not fiirng and then got a mobile diesel diagnostics chap over last night to be told the cam timing and crank timing are out of synchronisation. We could also hear what sounds like blow-back through air filter in one of the cyclinders when cranking, so not good.
I now need to fix it and see a number of options but would like some advice from those that have repaired this engine after a cambelt slip. The cam timing has not been physically checked so I don't know how many teeth it has slipped but cam is still turning. Worst case scenario is the engine is goosed but I'm hoping it's a replacment belt, rockers and possibly a bent valve/s but not having any experience with this engine I'm not sure what to expect and whether to strip van myself or get it into a Fiat specialist. Removing injectors and cam cover/timing cover might be first option to assess damage.
Any idea of likely costs to get this fixed?
