Hello
I have a Ducato 2.3jtd 2002 with https://www.fiatforum.com/# common rail
injection- Does this have an immobiliser code box problem ?
My [FONT=verdana,geneva,lucida,"][/FONT] fired up one morning just as normal drove 50 metres then
just cut out and hasn't started since.Everything was perfect before
that and it never missed a beat so I'm suspecting an electrical shut off
rather than a slow demise of the high pressure pump or injector
I can't find much technical info on this engine-I bought a disc
from ebay which wasn't much use and another from electronic manuals
which hasn't turned up yet.
The OBD apparently doesn't play ball with normal software as it's before
2004.
It has been suggested that the lift pump is faulty so we checked this and it
makes 10 psi in flow and return mode and builds a lot of pressure when it's flow is restricted.
There is a funny irregular buzzing noise coming from behind the [FONT=verdana,geneva,lucida,"][FONT=verdana,geneva,lucida,"][/FONT][/FONT][FONT=verdana,geneva,lucida,"] [/FONT]cover which whatever this is runs on the same power circuit as the lift pump.
Any ideas on this ?
2004.
Any ideas on this ?
