hi all,
i have some question i hope u guys are able to help me regarding the dualogic,
i just got the vagcom cable and multiecuscan, i did a final service(end of line) calibration, as the test is going on, where the gearbox is selecting thru all the gears, the dashboard shows a msg "gearbox failure" is this normal? or there is a serious problem with my transmission.
There is no error/fault code and it shows completed after its done.
I posted awhile back that my dualogic clutch was sticking.
https://www.fiatforum.com/panda/314811-clutch-sticking.html
and while i am driving, sometime as it change gear i can help a knock sound(i am guessing it is the gear change solenoid) is this normal?
thank you.
thank you.
