Technical  2008 Panda dualogic gear box problem
Williamchai
Crewe
I have a 2008 Panda 4x4 with dualogic gear box. It can shift into gear 3 and show operation not admissible. What’s the problem? Does anyone know it is possible to fix it? Thank you so much
While trying to select 3rd
Does not sound good
Is this the same in manual and auto modes
Hydraulic oil level first, then scan the code
Normal engine scanner will not connect to the selespeed control unit
Do you have anything to read the code with
