General drivers side headlight bulbs
J J
Bloody Ities
leicester
Ok i know i've kind of asked this before but i need to change the main beam and fog light bulb on the drivers side and i was wondering if i could do this or is it a garage job,
Jason
would i have to take the water bottle off to get to the main beam bulb
The main beam drivers side is easy - all you need to do is remove the top retaining nut of the water bottle, ease it off, and then push it back slightly - this gives you all the room you need to take off the back cover of the headlight unit, and hence replace the bulb.
No; the main beams are towards the middle of the car and are by far the easiest to get to.
I'd change them on both sides if I was you with +50% bulbs
Edit: Stu is talking about the dipped beam
How hard is it to do on the passengers side
As I said the main beam is easy but you might regret changing the dipped beam (especially if it's still working)
If you intend to change all 4 then I'd strongly recommend you read all the threads on the subject (there are many) - just use SEARCH
well i've just changed my main beam and fog light bulbs and it only took me 10 minuites
easy
