Hi all ! After replacing my front right drive shaft (with ABS) for the second time with a used-part that is worse than the last, I wonder if anyone has done a drive shaft revision ?
A new shaft from AutoDoc has a toothed wheel-side hub. Mine is a smooth hub. The problem is on the transmission side hub ( ticks when accelerating into a right-hand turn ). Any ideas floating around out there in B-land ?
grtz
ER
grtz
ER
