Technical Door lock lube.
Zog
Established member
Is it necessary or useful (or likely to cause a problem!) to squirt some silicone oil or other lubricant into the door locks?
On the scudo its always a good idea to lube the locks at least once a month. Silicone or good old wd40.
Just spray some into the keyhole?
Yes, Usualy there is a straw with wd40, I usualy push the straw into the lock and give it a blast once a month. I never suffer from the common problem of spinning locks that has been a regular topic of disscusion on this forum. (y)
