General  Does your Multi give you a stiffy...?
MarkX
...stiff neck that is!
...because, if your Multi dashboard is like mine, you have to twist your neck to the side to see what the speedo's reading?
Or are you Italian, and don't care what speed you're going? ;)
Well in case 1, here's the perfect solution?
Anyone got one?
I want it. It's so cool. I wonder if you can get it to display the football scores?
Mark
PS. I know the moderator hates external links, so here's a pic of the webpage instead...
It looks expensive, it would double the value of my 2000 model. I use a cheaper solution; stick my sat nav at the bottom of the windscreen and use that.
currently selling for £51.58 on 'carparts4less'
Also read the PDF instruction manual (google is the answer!!) and seems a bit of a 'faf' to setup and you have to put the 'transmitter' box on the dash in front of the windscreen (not too easy on the multi, as that 'cubby' pocket is curved all ways!!. Also, you have to put a 'film' on the windscreen to project onto??
