General DOBLO Maxi 1.6 Multijet - idle at startup
Any error codes showing on diagnostics or live data?
Nope, I use carsoft diagnostic tool. On live data the accelerator position shows change when I press on it but the vehicle doesn’t react until it moves past the rough idle.
Does the live data show common rail fuel pressure at that point?
Does the live data show oil pressure at that point?
Just to eliminate them.:)
Yes the live data shows the fuel rail pressure and what the pressure demand is. At start up the demand is 25000kpa which the pressure sensor matches. Once the rough idle finishes the demand asks for 32000kpa which again the sensor matches with the idle rpm increased to normal. There is no oil pressure live data only the pressure switch which states low then ok after a couple seconds in conjunction with the oil pressure light on the dashboard.
Fuel seems about right and matching demand/revs.
Do you have any more suspicions re the oil pressure side, I don't know anything concrete regarding that, but if whether real or due to a suspect sensor if low oil pressure it may be a reason for the ECU to prevent any load on the engine.
I don't know if it is possible to get a physical oil pressure gauge measurement to compare.
Maybe another Forum Member has knowledge on this?
Or if cheap and easy to replace try a new oil pressure sensor.
In general terms is the engine "older higher mileage" as in oil gets dirty very quick?
Not everyone agrees , but I am a fan of using Wynns engine flush on any vehicle I buy to clean out any old gunk then fit new oil and filter and do the same at subsequent oil changes.
I suppose if it has done a few miles the oil strainer in sump could be partially blocked resulting in the oil pump struggling to suck up oil from cold.
The rough idle seems to happen regardless of the oil pressure light illuminating or not. The van has done 94k miles I purchased at 84k without this problem. Had a full service including belt and water pump in November at 90k miles. The issue was happening before the service and still the same after the service. It had the DPF removed and flushed when I purchased the vehicle aswell.
I have just been playing around with the obd scanner. Usually I just go into check obd and read fault codes which says 0 codes found. However I just went into the in-depth diagnostic section and all control modules are showing the same fault P0200 injector low current. 🤔
Not a code I have come across, so possibly a wiring issue , poor connection/corrosion etc. Though strange how it goes away when warm.
Mine is around 106k miles and has had other issues , but not what you are experiencing.
Any more thoughts on the oil pressure side?
Tbh the code is there all the time, I can’t even clear it. I might try swap the oil pressure switch however when I just got in the van there was no oil pressure warning but the rough idle still happened for like 30 seconds and then finally kicked in and a puff of white smoke came out the back.
White smoke/unburnt fuel and slow/uneven on starting tends to point to heater plugs and low compression, not firing on all four cylinders straight away but I assume that has already been ruled out.
Yes i have replaced all 4 plugs and tested voltage ok. Starts fine like no long or slow cranking beforehand. Literally turn key and starts but sounds like as you said not firing on all 4.
It's the puff of white smoke that bothers me, if it smells of unburnt fuel and you have ruled out the heater plugs.
Does it use oil a bit, like worn piston/rings?
If so a compression test is one direction, trouble is not a five minute job on a diesel.
Oil hasnt dropped at all since its service in November. I honestly don't know at this point. I was debating removing the injectors and getting them tested as I saw another post similar to this problem and they found 1 injector to be faulty.
If you are pulling the injectors anyway, it may be worth testing compressions.
My thoughts generally on injectors is most problems are black smoke and too much fuel as they wear, also unlikely to only be on starting.
I don't claim to know everything though and at 70 probably forgetting most of it.;)
haha thanks for you help, Yeah i'll do a compression test aswell then when i pull the injectors. Just need to find time to do it considering i use it for work 😅
I’m having the exact same problem with my van, 2015 1.6 doblo 65k miles recently had service replacing glow plugs n fuel filter as well, also needed a new oil separator. Appeared better at first but think that was just regular usage and being warmer. Left it for over a day though and it did same thing for about 10 seconds, found a kinda similar post on a forum here:
Turned out was the alternator.
Have you had any luck solving this yet? Can you let me know how you’ve been getting on?
I saw that post aswell. I have replaced the alternator after following that thread but it did not fix the issue. I have also swapped the glow plug control module. I have now decided to take it to a garage to be investigated. Booked in for Tuesday. I will update the thread of the outcome.
That’s magic I look forward to your reply. Stressing me out cause need a reliable vehicle for emergency purposes as I need to get to a n e regularly at the drop of a hat.
I had once left it sitting for 2 weeks and wouldn’t start, AA said it was injectors which I had checked n replaced one.
It doesn’t happen every time, appears to be linked to the cold or if I leave it sitting longer between using.
Thanks again really hope garage can solve it for you.
So an update from the garage visit on Thursday. They thought the MAF sensor was the issue so cleaned it and ran some tests which didn’t solve the problem. They now suspect injectors but can’t be certain so have recommended me to visit a diesel specialist garage. I am currently trying to contact one to see if I can get it booked in.
Yes, does sound a bit outside their comfort zone.:)
Initially I was told it was the injectors and there was excess fuel in engine, in my head I thought one of them was slightly leaking and caused a build up of diesel which caused the rough idle at first till it burnt it off. Why it was worse when left for longer.
But once I had them off and checked one came back as under performing with amount of diesel coming out, guy said he would have still used it but I changed it thinking it would solve this problem.
Let’s say it is an injector slightly leaking, is that possible n would these symptoms make sense? When I had removed them n had them checked would it not have identified this? If not…
I still have the old spare, would you recommend me swapping one at a time for a couple of days to see if it solves the problem? Cause surely the chances of more than one injector doing this would be slim. I replaced studs and bolts when they were checked as one of the previous studs was bit dodgy so they all got put in with thread lock, so would prefer knowing if this was a good idea before touching them?
I’m honestly not sure, the garage said that he would be surprised if injectors are at fault as it’s below 100k miles. That’s why he’s recommending a diesel specialist rather than just going ahead with injectors.
